The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
Test No. LE1 The model is a thin plate of thickness 0.1m subjected to a uniform pressure for linear static analysis. OptiStruct examines the direct stress at the point on inside the ellipse on the x-axis.
Test No. LE3 The model is a hemispherical shell subjected to concentrated radial loads at its free edges. It examines the performance
of the three-dimensional shell to model local bending behavior under conditions where the deformations are
primarily due to bending.
Test No. LE10 The model is a thick plate subjected to uniform normal pressure of 1MPa on the upper surface of the plate. OptiStruct examines the direct stress at the point D for linear static analysis.
Test No. LE11 The model is a thick solid cylinder subjected to linear temperature gradient in the radial and axial direction. OptiStruct examines the direct stress at the point A inside the cylinder on the y axis for linear static analysis.
This problem examines the expansion of a pressure vessel due to an internal pressure. OptiStruct examines the principal stresses in the pressure vessel, due to the applied loading and boundary conditions.
OS-V: 0010 Elliptic Membrane Test No. LE1 The model is a thin plate of thickness 0.1m subjected to a uniform pressure for linear static analysis. OptiStruct examines the direct stress at the point on inside the ellipse on the x-axis.
OS-V: 0020 Cylinder Shell Patch Test No. LE2OptiStruct examines the outer surface tangential stress at point E for linear static analysis.
OS-V: 0030 Radial Point Load on a Hemisphere Test No. LE3 The model is a hemispherical shell subjected to concentrated radial loads at its free edges. It examines the performance of the three-dimensional shell to model local bending behavior under conditions where the deformations are primarily due to bending.
OS-V: 0040 Z-Section Cantilever Test No. LE5OptiStruct examines the axial (x-x) stress (compression) at mid-surface, point A for linear static analysis.
OS-V: 0050 Skew Plate Normal Pressure Test No. LE6OptiStruct examines the maximum principal stress on the lower surface at the plate center point E for linear static analysis.
OS-V: 0060 Thick Plate Pressure Test No. LE10 The model is a thick plate subjected to uniform normal pressure of 1MPa on the upper surface of the plate. OptiStruct examines the direct stress at the point D for linear static analysis.
OS-V: 0070 Solid Cylinder/Taper/Sphere - Temperature Test No. LE11 The model is a thick solid cylinder subjected to linear temperature gradient in the radial and axial direction. OptiStruct examines the direct stress at the point A inside the cylinder on the y axis for linear static analysis.
OS-V: 0085 Plane Strain: Analysis of Pressure Vessel
