The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
OS-V: 0100 Membrane with Hot-Spot Test No. T1OptiStruct examines the direct stress in y direction at a point D outside the hot-spot for linear thermos elastic analysis.
