.#.els.# file
The .#.els.# file is a Patran 2.5 ASCII format results file.
File Creation
This file is created when the Patran format is chosen and linear static analysis is performed. (See documentation for the I/O Option OUTPUT).
File Contents
Result Description
Stress Stress results from linear static analysis. Output is controlled by the I/O option STRESS (or ELSTRESS).
  1. One such file is created for each subcase at each iteration where the I/O Option RESULTS requests analytical results to be output.
  2. The first # in the file name is the user-defined Subcase ID.
  3. The second # in the file name is the iteration number.
