.seplot file
The .seplot file is an ASCII format output file.
File Creation
This file is created when the MODEL, PLOT, and PARAM, SEPLOT options are presented and the CBN method is used to reach a Component Mode Synthesis solution.
File Contents
This file contains grid and plot element definitions.
- By including this file in a residual run, the results of the superelement part will be recovered and post-processed.
