_s#_d.#.frf file
The _s#_d.#.frf file is an OptiStruct ASCII format results file.
File Creation
This file is only created for frequency response optimization. Output is controlled by the I/O Option DISPLACEMENT and OUTPUT,HGFREQ.
File Contents
This file contains the displacement results from frequency response optimization.
File Format
Frequency"REA | X Trans"IMA | X Trans"REA | Y Trans"IMA | Y Trans"REA | Z Trans"IMA | Z Trans |
Frequency"PHA | X Trans"MAG | X Trans"PHA | Y Trans"MAG | Y Trans"PHA | Z Trans"MAG | Z Trans |
Frequency | X-rl/ph | X-im/mag | Y-rl/ph | Y-im/mag | Z-rl/ph | Z-im/mag |
- Data
- Description
- Frequency
- The frequency at which results are calculated.
- X-rl/ph
- Is either the real component in the x-direction or the phase angle in the x-direction component.
- X-im/mag
- Is either the imaginary component in the x-direction or the magnitude in the x-direction component.
- Y-rl/ph
- Is either the real component in the y-direction or the phase angle in the y-direction component.
- Y-im/mag
- Is either the imaginary component in the y-direction or the magnitude in the y-direction component.
- Z-rl/ph
- Is either the real component in the z-direction or the phase angle in the z-direction component.
- Z-im/mag
- Is either the imaginary component in the z-direction or the magnitude in the z-direction component.
- The first # in the file name is the user-defined subcase ID.
- The second # in the file name is the iteration number.
- The _freq.#.mvw HyperView script file automatically creates plots for the results contained in this file.
