_nlm.mvw file
The _nlm.mvw file is a HyperGraph session file.
File Creation
This file is only created when an NLOUT entry is specified in a Large Displacement Nonlinear Analysis model.
File Contents
This file is a HyperGraph session file and may be opened from the File pull-down menu in HyperGraph. The file automatically creates plots for the results contained in the _e.nlm file.
