Altair Inspire Cast 2020 Release Notes
Altair Inspire Cast 2020 includes the following new features and enhancements.
New Features
- Licensing and Altair Units
- solidThinking Units and HyperWorks Hosted Units have been replaced with Altair Units for version 2020.
- User Interface Enhancements
- The Inspire Cast user interface has been updated for 2020 and features several new themes, as well as changes to selection and pre-highlighting colors. If you prefer the old background theme, just select Blue Twilight in the Preferences under Workspace > Theme.
- Analysis Explorer Enhancements
- The Analysis Explorer allows you to filter the results so that areas on the model with results greater than a specified value are masked. In addition, a Scale Factor option has been added to the animation settings window.
- Simulation Parameters Information
- Users can now quickly access all of the simulation settings used in a run in the Analysis Explorer. This includes information about the components, process parameters, stages, mesh, and model.
- Mold Roughness
- Users now have the option to select from three surface finishes to simulate friction between the liquid and the mold.
