hwIH3DExportOptions SetCompressOutput
Sets whether to apply compression to results during output.
hwIH3DExportOptions_handle SetCompressOutput flag
HyperWorks Tcl Query
Compression is comprised by two processes: lossy and non-lossy. To produce lossless compression, turn compression on and set the allowable error to zero.
This command is related to the H3D option on the Publish Session dialog.
flag
True or false.
To enable compression:
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetCompressOutput true
None.
