hwISession GetXMLFileHandle
Gets the XML file handle.
hwISession_handle GetXMLFileHandle datafile, filename
HyperWorks Tcl Query
This command gets the XML file handle. Note: To test if the file is actually an XML file, IsValid must be called.
datafile
The name that you want to call the XML file handle.
filename
The filepath of the file that you want to get the XML handle of. Note: If the filepath has spaces in it, the entire filepath must be within quotes.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML “c:/Documents and Settings/user/My Documents/hwsettings.xml”;
XML IsValid
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
XML
Query
