hwISession PublishSession
Publishes the current session in either the HTML or XML format.
hwISession_handle PublishSession filename, frame_width
HyperWorks Tcl Query
This command replaces the command hwIPage ExportHTMLReport.
This command uses the current values for the hwIAVIExportOptions, hwIH3DexportOptions, and hwIJPGExportOptions objects in the current session. To manipulate these values, obtain a handle to the desired object and set the desired property before executing this command.
filename
The filename of the HTML or XML report.
frame_width
The width (as a percentage of the screen) of the browser frame. Values can be from 10 to 40 (inclusive).
To export the contents of the current session to an HTML or XML report:
mySessionName PublishSession myReportName 20
Error
Success (0) or an error code.
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
