hwISession RegisterSpaceballCallback
Allows registration of Tcl callbacks for Spaceball button events.
hwISession_handle RegisterSpaceballCallback buttonId, procName
HyperWorks Tcl Query
buttonID
The button ID to register a callback against. Valid values are identified by calling the GetSpaceballButtonMin and GetSpaceballButtonMax commands.
procName
The name of the procedure to call when the Spaceball event occurs. The procedure takes a state parameter, which is the state of the button at the time that it is pressed.
True
Indicates the button is pressed.
False
Indicates the button is released.
If the procedure is not in the Tcl global namespace, the namespace must be specified.
Error
Success (0) or an error code.
