hwISession SetUserVariable
Associates a value to a variable on the session level.
hwISession_handle SetUserVariable variable, value
HyperWorks Tcl Modify
variable
The variable name associated with the session level.
value
The value associated with the variable.
mySessionName SetUserVariable last_run run_5
Error
Success (0) or an error code.
