pltIPlot GetTipToTailLineStyle
Gets the line style of the tip-to-tail curve. Finds the style of the arrow in a polar plot.
pltIPlot_ctrl GetTipToTailLineStyle
HyperGraph Polar Plot/Tip to Tail functionality.
This command gets the line style of the tip-to-tail curve. The return value is a number between 1 and 5 that specifies a line style for the tip-to-tail curve.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetTipToTailLineStyle;
Success (a number between 1 and 5) or an error message is returned.
