pltIPlot SetTipToTailLineThickness
Sets the thickness of the arrow in a polar plot.
pltIPlot_handle SetTipToTailLineThickness thickness
HyperWorks Tcl Modify
This command sets the thickness of the arrow in a polar plot based on the number input.
Note: This method is only valid for polar plots.
thickness
The number corresponding to the thickness style that you want to use. There are four thickness types, with the numbers 0-3 represent each thickness type.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot SetTipToTailLineThickness 0;
Keywords
HyperWorks
Tcl
Polar plot
Modify
