Create Fields
Learn how to create fields.
Before creating a field, import the target model or analysis file that contains the new mesh into your current HyperMesh session.
  1. In the Model Browser, right-click and select Create > Field from the context menu.
  2. In the Entity Editor, select one of the following field types:
    • Continuous fields evaluate data based on the shape function of source mesh data and its nodal or elemental values. If the location of the x,y,z points or u,v points are well structured in a rectangular array, a source mesh can be constructed.
      Source data contains the mesh and the nodal or elemental values. The target mesh is different from the source mesh.
    • Discrete fields provide data on discrete x,y,z locations (real) or u,v locations (parametric), without the source mesh. Depending on the fitness of the data points, the closest point approach or inverse distance linear interpolation method will be used to map.
  3. Select one of the following System types:
    • Real coordinate systems (x,y,z values)
      Figure 3.
    • Parametric systems (u,v tables)
      Figure 4.
  4. Select one of the following Sources to create the field:
    • Results: loads an existing results file.
    • Current Model: imports an analysis data file (.bdf, .fem, .inp, and so on). If you select Current Model, you will see the following fields:
      • Data Source Type
      • Source Entity List
    • CSV file: loads a .csv file containing x,y,z, value1, value2 discrete data.
    • Matrix: loads a matrix file which will be used to generate data using matrix query tools.
    • HV Current Contour
