FORAN Reader
Supported Entities
Entities supported by the FORAN reader:
  • All entities supported by the STEP reader
  • Model hierarchy and organization from the XML file
The FORAN reader requires a STEP (.stp) file and a correspondingly named FORAN XML (.xml) file to exist in the same directory. It reads data from the STEP file using the STEP reader and then reads the FORAN XML file to generate the relevant model hierarchy and organization.
Import Options
The FORAN reader uses the ct_reader.ini file and has the same options as the STEP reader.
Supported Metadata
The FORAN reader generates the same metadata as the STEP reader, with some additional metadata generated from the FORAN XML file.
FORAN_COG_X
Type Entities Description
double parts The plate or profile COG x-coordinate.
FORAN_COG_Y
double parts The plate or profile COG y-coordinate.
FORAN_COG_Z
double parts The plate or profile COG z-coordinate.
FORAN_COLOR
string parts Three comma-separated RGB values, ranging from 0 to 255, indicating the color for the object.
FORAN_INERTIA_X
double parts The profile inertia x-value.
FORAN_INERTIA_Y
double parts The profile inertia y-value.
FORAN_INERTIA_Z
double parts The profile inertia z-value.
FORAN_MATERIAL
string parts The plate or profile material name.
FORAN_PART_ID
string parts The plate or profile ID.
FORAN_PART_OID
string parts The plate or profile OID.
FORAN_SCANTLING
string parts The profile scantling name.
FORAN_SECTION_AREA
double parts The profile section area.
FORAN_THICKNESS
double parts The plate thickness.
