Patch and Delete Surfaces
Use the Surfaces: Patch tool to create patch surfaces between free lines that are not connected or surface edges. You can also delete surfaces with this tool.
Surfaces: Patch Tool
An overview of the Surfaces: Patch tool.
- Access
- Go to .
Keyboard Shortcuts and Mouse Controls
To do this | Press |
Drag/select lines | Left Mouse Click |
Patch a surface hole | Double-Click |
