/ALE/MAT
Block Format Keyword Describes the ALE material.
/ALE/MAT/mat_ID | |||||||||
Flrd |
mat_ID | Material
Flrd | Modification
factor on boundary surfaces fluxes.
(Real) |
#RADIOSS STARTER
#- 1. MATERIALS:
/MAT/LAW37/1
air (unit g_mm_ms)
# Psh
0
# RHO_l0 C_l ALPHA_l NU_l NU_VOL_l
.001 2089 0 .001 0
# RHO_G0 GAMMA P0 NU_g NU_VOL_g
1.22E-6 1.4 .1 .00143
/ALE/MAT/1
# Modif. factor.
0
#enddata
- If the boundary is not connected to a material specifying an Elementary Boundary Condition (TYPE11), the Flrd is by default 0. The flow is reduced otherwise by the Flrd factor value specified at the elementary boundary level.
