/BULKPROP
Optimization Keyword Defines Bulk Format Data to be used as the conversion data for Radioss property data (/PROP) into the intermediate OptiStruct input file during Design Optimization.
/BULKPROP/prop_ID
title
Bulk Format Data
prop_ID Property identifier
(Integer)
title Property title
Bulk Format Data Bulk Format Data to be used as the conversion data for Radioss property data (/PROP) into the intermediate OptiStruct input file.
The Radioss property entry (/PROP) defined in the Starter input file with prop_ID = 6 will be converted into OptiStruct PSHELL entry.
/BULKPROP/6
Conversion of prop_ID=6
PSHELL,6,1,1.0,1,,1,0.79
  1. All element properties in OptiStruct are supported in /BULKPROP.
