Limitations (may coexist, but out of the selected AMS part group)
- SPH: AMS does not increase time step of SPH (example: tank sloshing in crash)
- ALE - Euler - FVM: formulations are not supported (but can be put out of /AMS part, if time step is decent)
- 2D analysis: /AMS is not available
- Parts involving:
- Lagrange multipliers: /MPC and /GJOINT
- /FXBODY
In such cases, a warning is output by Radioss Engine and the computation may even diverge.
- Elements:
- 4-node tetra: /TETRA4 with Itetra=1 or 3
- 16-node shell: /SHEL16
- 20-node bricks: /BRIC20
In such cases, the computation will most likely diverge.
- Rigid bodies cannot be activated and deactivated with sensors
- Interfaces: /DT/INTER/CST is not compatible with /DT/AMS
- Nodes that are slave of both: a tied interface TYPE2
and a contact interface (TYPE7 or
TYPE11) will have their contact stiffness removed
a Starter message in the 0.out file is then
issued:
** WARNING SLAVE NODE OF AN INTERFACE TYPE2 & AMS INTERFACE TYPE[7 or 11], ID=xxxxxx: SLAVE NODE ID=yyyyyyy IS ALSO SLAVE NODE OF AN INTERFACE TYPE2 THE NODE CONTACT STIFFNESS WILL BE DE-ACTIVATED CASE OF /DT/AMS
This contact deactivation can be avoided by using Spotflag=25, 27 or 28 (TYPE2 penalty formulation).
- Kinematic formulation (TYPE2) for spotwelds may alter AMS performances when there are many spotwelds, particularly hexa spotwelds.
issued:
- Airbags with reference metrics: /REFSTA or /XREF do not benefit AMS speedup.
- Refer to the Starter Input and Engine Input Reference Guides.
Elementary time step for
AMS /DT/AMS in Radioss Engine Input |
Lagrange Multipliers | Does not work |
16-node thick shells and 20-node bricks | Free element time step is applied to these elements |
Rigid bodies activated, deactivated with sensors | Does not work |
Interfaces | Only TYPE2, TYPE7, TYPE10, TYPE11, TYPE19, TYPE20, TYPE21, and TYPE24 are supported |
