/FRIC_ORIENT
Block Format Keyword Define specific directions for orthotropic contact friction for the master surface for contact interfaces TYPE7, TYPE19, TYPE24, and TYPE25.
These orientations are used when an orthotropic friction model is defined in /FRICTION Idir=1. Only shell elements are supported.
/FRIC_ORIENT/fric_ID | |||||||||
friction_orientation_title |
/FRIC_ORIENT/fricorient_ID | |||||||||
friction_orientation_title | |||||||||
grpart_ID | part_ID | ||||||||
VX | VY | VZ | Skew_ID | Iorth |
fric_ID | Friction
friction_orientation_title | Friction model
grpart_ID | Part group identifier
/GRPART. (Integer) |
part_ID | Part
identifier. Ignored if, grpart_ID is defined. (Integer) |
VX | X component for
reference vector. Default = 1.0 (Real) |
VY | Y component for
VZ | Z component for
Skew_ID | Skew identifier for
reference vector. 2
If the local skew is defined, its X-axis replaces the global vector, . VX, VY and VZ coordinates are ignored. Default = 0 (Integer) |
Angle. 2 (Real) |
Iorth | Orthotopic system
formulation flag for reference vector.
(Integer) |
- These friction directions replace the orthotropic directions defined in the property for defined parts.
- Orthotropy in local
coordinate system via two different ways:
- Skew_ID =0: Orthotropic direction defined with global vector (components defined in Line 4) and angle (angle in degree).
- Skew_ID ≠0: Orthotropic direction defined with skew (X-axis in skew replaces the global vector ) and angle (angle in degree).
For both ways (with vector or with skew), the projection of vector (or x-axis of skew) on shell element plane becomes the vector . Then the orthotropic direction (direction 1) is vector turned degrees where the positive direction is based on the shell normal .
