/INTER/TYPE7
Block Format Keyword Interface TYPE7 is a multi-usage impact interface, modeling contact between a master surface and a group of slave nodes. It is also possible to consider heat transfer and heat friction.
- A node can at the same time be a slave and a master node.
- Each slave node can impact each master segment; except if it is connected to this segment.
- A node can impact on more than one segment.
- A node can impact on the two sides, on the edges and on the corners of each segments.
- It is a fast search algorithm without limitations.
- Time step is reduced in case of high impact speed or contacts with small gap.
- It does not work properly if used with a rigid body at high impact speed or rigid body with small gap.
- It does not solve edge to edge contact (to solve this, /INTER/TYPE11 should be used along with TYPE7).
/INTER/TYPE7/inter_ID/unit_ID | |||||||||
inter_title | |||||||||
grnd_IDs | surf_IDm | Istf | Ithe | Igap | Ibag | Idel | Icurv | Iadm | |
Fscalegap | Gapmax | Fpenmax | ITIED | ||||||
Stmin | Stmax | %mesh_size | dtmin | Irem_gap | Irem_i2 |
node_ID1 | node_ID2 |
Stfac | Fric | Gapmin | Tstart | Tstop | |||||
IBC | Inacti | VISs | VISF | Bumult | |||||
Ifric | Ifiltr | Xfreq | Iform | sens_ID | fct_IDF | AscaleF | fric_ID |
C1 | C2 | C3 | C4 | C5 |
C6 |
NRadm | Padm | Angladm |
Kthe | fct_IDK | Tint | Ithe_form | AscaleK | |||||
Frad | Drad | Fheats | Fheatm |
inter_ID | Interface identifier. (Integer, maximum 10 digits) |
unit_ID | unit_ID. (Integer, maximum 10 digits) |
inter_title | Interface title. (Character, maximum 100 characters) |
grnd_IDs | Slave nodes group
identifier. (Integer) |
surf_IDm | Master surface
Istf | Interface stiffness definition flag.
3
For SPH, only Istf=0,
1 and 1000 are available.
(Integer) |
Ithe | Heat contact flag.
(Integer) |
Igap | Gap/element option flag. 11
(Integer) |
Ibag | Airbag vent holes closure flag in case
of contact. This flag is also used to activate Sol2SPH particles, if the
corresponding solid element is in contact.
(Integer) |
Idel | Node and segment deletion flag.
(Integer) Note: Idel = 1 and
-1 has a higher CPU cost when compared with Idel = 2 and
-2.
Icurv | Gap envelope with curvature. 5
(Integer) |
Iadm | Computing local curvature flag for
adaptive meshing. 6
7
8
(Integer) |
Fscalegap | Gap scale factor (used only when Igap = 2 and
3). Default = 1.0 (Real) |
Gapmax | Maximum gap (used only when Igap = 2 and
3). (Real) |
Fpenmax | Maximum fraction of initial penetration.
13 (Real) |
ITIED | Tie contact nodes flag.
(Integer) |
Stmin | Minimum stiffness (used only when Istf = 2,
3, 4, or
5). (Real) |
Stmax | Maximum stiffness (used only when Istf = 2,
3, 4, or 5). Default = 1030 (Real) |
%mesh_size | Percentage of mesh size (used only when
Igap = 3). Default = 0.4 (Real) |
dtmin | Minimum interface time step. 23
(Real) |
Irem_gap | Flag for deactivating slave nodes if
element size < gap value, in case of self-impact contact. 14
(Integer) |
Irem_i2 | Flag for deactivating the slave node, if
the same contact pair (nodes) has been defined in interface TYPE2.
node_ID1 | First node
node_ID2 | Second node identifier (ignored when Igap =
1). (Integer) |
Stfac | Stiffness scale factor applied to master
side of the interface (if Istf
1). Default = 1.0 (Real) |
Interface stiffness (if Istf = 1). Default = 1.0 (Real) |
Fric | Coulomb friction (if fct_IDF = 0). Default = 0.0 (Real) |
Coulomb friction scale factor (if fct_IDF
0). 20 Default = 1.0 (Real) |
Gapmin | Minimum gap for impact activation. For default values, see 10 (Real) |
Tstart | Start time. (Real) |
Tstop | Time for temporary
deactivation. (Real) |
IBC | Deactivation flag of boundary conditions
at impact. (Boolean) |
Inacti | Deactivation flag of stiffness in case
of initial penetrations. 13
(Integer) |
VISs | Critical damping coefficient on
interface stiffness. Default set to 0.05 (Real) |
VISF | Critical damping coefficient on
interface friction. 22
Default set to 1.0 (Real) |
Bumult | Sorting factor is used to speed up the
sorting algorithm and is machine dependent. Default set to 0.20 (Real) |
Ifric | Friction formulation flag. 1617 Only used if fric_ID is not defined.
(Integer) |
Ifiltr | Friction filtering flag. 18
(Integer) |
Xfreq | Filtering coefficient. This coefficient should have a value between 0 and 1. Default = 1.0 (Real) |
Iform | Friction penalty formulation type. 19
(Integer) |
sens_ID | Sensor identifier to activate/deactivate
the interface. 24 If an identifier sensor is defined, the activation/deactivation of interface is based on sensor and not on Tstart or Tstop. (Integer) |
fct_IDF | Friction coefficient with temperature
function identifier. Default = 0 (Integer) |
AscaleF | Abscissa scale factor on fct_IDF. Default = 1.0 (Real) |
fric_ID | Friction identifier for friction
definition for selected pairs of parts.
(Integer) |
C1 | Friction law
coefficient. (Real) |
C2 | Friction law
C3 | Friction law
C4 | Friction law
C5 | Friction law
C6 | Friction law
Kthe | Heat exchange coefficient (if fct_IDK = 0). Default = 0.0 |
0). 20
fct_IDK | Function identifier for thermal heat
exchange definition with contact pressure. Default = 0 (Integer) |
AscaleK | Abscissa scale factor on fct_IDK. Default = 1.0 (Real) |
Tint | Interface temperature. 20 (Real) |
Ithe_form | Heat contact formulation flag.
(Integer) |
NRadm | Number of elements through a 90 degrees
radius. (Integer) |
Padm | Criteria on the percentage of
penetration. Default = 1.0 (Real) |
Angladm | Angle criteria. (Real) |
Frad | Radiation factor. (Real) |
Drad | Maximum distance for radiation
computation. (Real) |
Fheats | Frictional heating factor of slave.
21
(Real) |
Fheatm | Frictional heating factor of master.
21
(Real) |
Flags for Deactivation of Boundary Conditions: IBC
(1)-1 | (1)-2 | (1)-3 | (1)-4 | (1)-5 | (1)-6 | (1)-7 | (1)-8 |
IBCX | IBCY | IBCZ |
IBCX |
(Boolean) |
IBCY |
(Boolean) |
IBCZ |
(Boolean) |
- In case of SPMD, each master segment defined by surf_IDm must be associated to an element (possibly to a void element).
- For the flag Ibag, refer to the monitored volume option (Monitored Volumes (Airbags)).
- Contact stiffness, K
is computed as:If Istf =1:
(1) If Istf = 2, 3, 4 or 5:(2) If Istf =1000:(3) Where, is computed from both master segment stiffness and slave node stiffness :
Istf = 2,
Istf = 3,
Istf = 4,
Istf = 5,
is the master segment stiffness and computed as:
When the master segment lies on a shell or is shared by shell and solid:(4) When the master segment lies on a solid:(5) Where,- Segment area
- Volume of the solid
- Bulk modulus
is an equivalent nodal stiffness considered for interface TYPE7, and computed as:
When the node is connected to a shell element:(6) When the node is connected to a solid element:(7) There is no limitation to the value of stiffness scale factor Stfac (but, a value greater than 1.0 can reduce the initial time step).
When using /PROP/VOID and /MAT/VOID, material properties and thickness for the VOID material must be entered; otherwise, the contact stiffness of the void elements will be zero. This is especially important if VOID shell elements share elements with solid elements as the stiffness of the shell elements is used in the contact calculation.
- Istf = 2, 3, 4, or 5 are not compatible with SPH formulation.
- If Icurv = 1, a spherical curvature
is defined for the gap with node_ID1 (center of the sphere).
If Icurv = 2, a cylindrical curvature is defined for the gap with node_ID1 and node_ID2 (on the axis of the cylinder).
If Icurv = 3, the master surface shape is obtained with a bicubic interpolation, respecting continuity of the coordinates and the normal from one segment to the other. In case of a fast and large change in curvature, this formulation might become unstable (will be improved in future version).
Figure 1. - In case of adaptive meshing and Iadm = 1: If the contact occurs in a zone (master side) whose radius of curvature is lower than the element size (slave side), the element on the slave side will be divided (if not yet at maximum level).
Figure 2. - In case of adaptive meshing and Iadm = 2:
If the contact occurs in a zone (master side) whose radius of curvature is lower than NRadm times the element size (slave side), the element on the slave side will be divided (if not yet at maximum level).
If the contact occurs in a zone (master side) where the angles between the normals are greater than Angladm and the percentage of penetration is greater than Padm, the element on the slave side will be divided (if not yet at maximum level).
Figure 3. - The coefficients NRadm, Padm, and Angladm are used only if adaptive meshing and Iadm=2.
- If Gapmax=0, there is no maximum value for the gap.
- If Gapmin=0 or blank, a default value
is computed as:
If master segments are shell and solid elements, Gapmin = min ( , ).
Where,- The average thickness of the master shell elements, for Igap=0
- The minimum thickness of the master shell elements, for Igap=1, 2, or 3
- The smallest side length of all master segments (shell or brick)
If master segments are all solid elements Gapmin =
Where, being the smallest side of all master brick segments.
- Variable gap:If Igap =1, variable gap is computed as:
(8) If Igap =2, variable gap is computed as:(9) If Igap =3, variable gap is computed for self-contact as:(10) Where,-
: master element gap
: with being the thickness of the master element for shell elements
: for brick elements
: slave node gap
: if the slave node is not connected to any element or is only connected to brick or spring elements
: with being the largest thickness of the shell elements connected to the slave node
: for truss and beam elements. With being the cross section of the element
- : length of the smaller edge of element
- : length of the smaller edge of elements connected to the slave node
If the slave node is connected to multiple shells and/or beams or trusses, the largest computed slave gap is used.
The variable gap is always at least equal to Gapmin.
- Deactivation of the boundary condition is applied to slave nodes group (grnd_IDs).
- Inacti = 3 may create initial
energy if the node belongs to a spring element.Inacti = 6 is recommended instead of Inacti =5, in order to avoid high frequency effects into the interface.
Figure 4.If Fpenmax is not equal to zero, nodes stiffness is deactivated if:
whatever the value of Inacti.
- With Irem_gap = 2, it allows to have the element size smaller than gap values:
Figure 5. Slave nodes removed from node to surface contactFor self-impact contact, when Curvilinear Distance (from a node of the master segment to a slave node) is smaller than (in initial configuration), this slave node will not be taken into account by this master segment, and it will not be deleted from the contact for the other master segments.
- One node can belong to the two surfaces at the same time.
- If fric_ID is defined, the contact friction is defined in /FRICTION and the
friction inputs (Ifric, C1,
etc.) in this input card are not used.
For friction formulation:
If the friction flag Ifric=0 (default), the old static friction formulation is used:
with being the Coulomb friction coefficient- If fct_IDF = 0:Ifric is the Coulomb friction.
(11) - If fct_IDF ≠ 0:Fric becomes a scale factor of Coulomb friction coefficient which depends on the temperature.
(12)
While is the temperature which is taken as the mean temperature of slave and master:(13) For flag Ifric > 0, new friction models are introduced. In this case, the friction coefficient is set by a function ( ).
Where,- Pressure of the normal force on the master segment
- Tangential velocity of the slave node relative to the master segment
- If fct_IDF = 0:
- Currently, the coefficients C1 through C6 are used to define a variable friction
coefficient
for
new friction formulations.The following formulations are available:
- Ifric = 1 (Generalized
Viscous Friction law):
(14) - Ifric = 2 (Modified Darmstad
law):
(15) - Ifric = 3 (Renard
law):
(16) (17) (18)
Where,- First critical velocity must be different to 0 ( ).
- First critical velocity must be less than the second critical velocity .
- The static friction coefficient and the dynamic friction coefficient , must be less than the maximum friction ( and ).
- The minimum friction coefficient must be less than the static friction coefficient and the dynamic friction coefficient ( and ).
Table 1. Units for Friction Formulations Ifric Fric C1 C2 C3 C4 C5 C6 1 2 3 - Ifric = 1 (Generalized
- Friction filtering:If Ifiltr flag 0, the tangential forces are smoothed using a filter:
(19) Where α coefficient is calculated from:- If Ifiltr = 1: , simple numerical filter.
- If Ifiltr = 2: , standard -3dB filter, with , and is the filtering period.
- If Ifiltr = 3:
, standard -3dB filter, with Xfreq = cutting frequency.
The filtering coefficient Xfreq should have a value between 0 and 1.
- Friction penalty formulation Iform:
- If Iform = 1 (default) viscous
formulation, the friction forces are:
(20) While an adhesion force is computed as:(21) - If Iform = 2, stiffness
formulation), the friction forces are:
(22) While an adhesion is computed as:
with
Where, is the tangential velocity of the slave node relative to the master segment.
Iform = 2 is recommended for implicit and low speed impact explicit analysis.
- Heat exchange:By Ithe =1 (heat transfer activated) to consider heat exchange and heat friction in contact.
- If Ithe_form = 0, then heat exchange is between shell and constant temperature contact Tint.
- If Ithe_form = 1, then heat exchange is between all contact pieces.
Tint is used only when Ithe_form= 0. In this case, the temperature of master side assumed to be constant (equal to Tint). If Ithe_form=1, then Tint is not taken into account, for the nodal temperature of master side will be considered.
Heat exchange coefficient:- If fct_IDK = 0, then Kthe is heat exchange coefficient and heat exchange depends only on heat exchange surface.
- If fct_IDK ≠ 0, then Kthe is a scale factor and the heat exchange
will depend on the contact pressure:
(23) - While is the function of fct_IDK.
- Heat Friction:
- Frictional energy is converted into heat when Ithe > 0 for interface.
- Fheats and
Fheatm are defined as the
fraction of frictional energy and distributed respectively to the slave side and
master side. So generally:
(24) When both Fheats and Fheatm are equal to 0, the conversion of the frictional sliding energy to heat is not activated.
- The frictional heat QFric is
defined:
- If Iform= 2 (a stiffness
formulation):Slave side:
(25) Master side:(26) (Ithe_form= 1) - If Iform= 1 (a penalty
(27) Master side:(28) (Ithe_form= 1)
formulation):
- Radiation:Radiation is considered in contact if and the distance, , of the slave node to the master segment is:
(29) While is the maximum distance for radiation computation. The default value for is computed as the maximum of:- Upper value of the Gap (at time 0) among all nodes
- Smallest side length of slave element
It is recommended not to set the value too high for , which may reduce the performance of Radioss Engine.
A radiant heat transfer conductance is computed as:(30) with(31) Where,- Stefan Boltzman constant
- Emissivity of slave surface
- Emissivity of master surface
- If the time step of a slave node in this contact becomes less than dtmin, the slave node is deleted from the contact and a warning message is printed in the output file. This dtmin value takes precedence over any model interface minimum time step entered in /DT/INTER/DEL.
- When sens_ID is defined for activation/deactivation of the interface, Tstart and Tstop are not taken into account.
