/INIMAP1D
Block Format Keyword Map 1D velocities and thermodynamic values into 2D or 3D space using spherical, cylindrical, or planar mapping methods. The mapped results are used with /ALE/EULER materials.
/INIMAP1D/form/inimap1d_ID | |||||||||
inimap1d_title | |||||||||
type | |||||||||
node_ID1 | node_ID2 | ||||||||
grbric_ID | grquad_ID | grtria_ID | |||||||
fct_ID1 | fct_ID2 | fct_ID3 |
form | Initial state formulation.
inimap1d_ID | Inimap1d block identifier. (Integer, maximum 10 digits) |
inimap1d_title | Inimap1d block title. (Character, maximum 100 characters) |
type | Initial mapping type. 2
(Integer) |
node_ID1 | Node 1 identifier. (Integer, maximum 10 digits) |
node_ID2 | Node 2 identifier, only if
type=1 or 2. (Integer, maximum 10 digits) |
grbric_ID | Brick group on which initialization is
performed. (Integer) |
grquad_ID | Quad group on which initialization is
grtria_ID | Tria group on which initialization is performed. (Integer) |
fct_ID1 | Function identifier for density
initialization. (Integer) |
fct_ID2 | Function identifier for specific
internal energy initialization (if
form=VE). Pressure initialization (if form=VP). (Integer) |
fct_ID3 | Function identifier for velocity
/INIMAP1D/VE/1
INIMAP1D for cylindrical mapping
# Type
2
# Node_ID1 Node_ID2
1 4
#grbric_ID grquad_ID grtria_ID
1 0 0
# fct_ID1 fct_ID2 fct_ID3
1 2 3
/INIMAP1D/VE/2
INIMAP1D for planar mapping
# Type
1
# Node_ID1 Node_ID2
2602 393299
2 0 0
1 2 3
/INIMAP1D2/VE/3
INIMAP1D for spherical mapping
# Type
3
# Node_ID1
5203
3 0 0
1 2 3
/FUNCT/1
RHO
0.00000000 1.00000000
0.25000000 1.00000000
0.50000000 0.25000000
0.65000000 0.30000000
0.70000000 0.20000000
0.80000000 0.20000000
0.81000000 0.12500000
1.00000000 0.12500000
/FUNCT/2
EINT
0.00000000 2.50000000
0.25000000 2.50000000
0.50000000 1.40000000
0.65000000 1.60000000
0.70000000 2.50000000
0.80000000 2.50000000
0.81000000 2.00000000
1.00000000 2.00000000
/FUNCT/3
VELOCITY
0.00000000 0.00000000
0.25000000 0.00000000
0.50000000 1.16000000
0.65000000 0.80000000
0.70000000 0.70000000
0.80000000 0.60000000
0.81000000 0.00000000
1.00000000 0.00000000
#enddata
- The option can be used to initialize a 2D or 3D simulation from the results of a 1D simulation potentially obtained from an external solver.
- Three different initialization types are
available depending on the type parameter:
- type = 1: a planar initialization is performed where the 1D results are mapped onto a plane which is normal to the vector defined from node_ID1 to node_ID2. The abscissa values in an input function are the distance along the plane’s normal vector. The ordinate values from the input function are a constant value for the entire plane at a given distance along the normal. See Figure 1 and Figure 2.
- type = 2: a cylindrical initialization is performed where the local z cylindrical axis is defined from node_ID1 to node_ID2. The abscissa values in an input function are the radial distance from the local z cylindrical axis. The ordinate values from the input function are a constant value for the entire cylindrical surface at given radial distance. See Figure 3 and Figure 4.
- type = 3: a spherical initialization is performed, using the origin defined by node_ID1. The abscissa values in an input function are the radial distance from origin. The ordinate values from the input function are a constant value for the entire spherical surface at given radial distance. See Figure 5 and Figure 6.
- When form=VE, the model is initialized from density, specific internal energy and velocity. This formulation is available for all mono-material ALE / EULER material laws and with material /MAT/LAW151 (MULTIFLUID) when only one sub-material is present.
- When form=VP, the model is initialized from
density, pressure and velocity. This formulation is available for all mono-material ALE /
EULER material laws whose equation of state is provided through the
/EOS card and with material /MAT/LAW151 when only
one sub-material is present.Figure 1. Mass Density (with input function) Planar Mapping on a 50 x 50 x 50 Cubic MeshFigure 2. Velocity (with input function) Planar Mapping on a 50 x 50 x 50 Cubic MeshFigure 3. Mass Density (with input function) Cylindrical Mapping on a 50 x 50 x 50 Cubic MeshFigure 4. Velocity (with input function) Cylindrical Mapping on a 50 x 50 x 50 Cubic MeshFigure 5. Mass Density (with input function) Spherical Mapping on a 50 x 50 x 50 Cubic MeshFigure 6. Velocity (with input function) Spherical Mapping on a 50 x 50 x 50 Cubic Mesh
