/MAT/LAW0 (VOID)
Block Format Keyword This material can be used to define elements to act as a void, or an empty space.
/MAT/LAW0/mat_ID/unit_ID or /MAT/VOID/mat_ID/unit_ID | |||||||||
mat_title |
E |
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density (Real) |
E | Young's
modulus (Real) |
Poisson's
ratio (Real) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/VOID/1/1
Void
# RHO E Nu
7.85E-9 210000 0.3
#ENDDATA
/END
- Only law, mat_ID, and mat_title are used (refer to the keyword Materials).
- This additional data allows defining contact interfaces with void material and property: all kinds of input for interfaces will then be available (Igap =1, Stfac as a stiffness factor).
- Contact stiffness will be correctly calculated only when E, and t (thickness in property) are given.
- When density of the void material is requested, the mass of the material is accounted in kinetic energy calculation.
