/MAT/LAW75 (POROUS)
Block Format Keyword Describes the P-α porous material model. This material describes ductile Porous material with Herrmann model. It only works with 8-node brick element and is not compatible with ALE.
/MAT/LAW75/mat_ID/unit_ID or /MAT/POROUS/mat_ID/unit_ID
mat_title
ρ i
E υ
mat_IDs Iflag1 Iflag2 itemax
PE Ps n
tol
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density for porous material
(Real)
[ kg m 3 ]
E Young's modulus
(Real)
[ Pa ]
υ Poisson's ratio
(Real)
mat_IDs Material identifier of the solid (fully compacted) material.
(Integer)
Iflag1 Pressure formulation flag.
= 1 (Default)
Herrmann. 1
= 2
Modified Herrmann. 2
(Integer)
Iflag2 Deviatoric stresses formulation flag.
= 1 (Default)
Hydrodynamic
= 2
Elastic
(Integer)
itemax Maximum number of iterations on a calculation.
Default = 5 (Integer)
PE Elastic compact pressure (elastic limit). 3
(Real)
[ Pa ]
Ps Solid (matrix) compact pressure. 3
(Real)
[ Pa ]
n Exponent used for fitting the experiment data. 3
Default = 2 (Real)
tol Convergence tolerance on a calculation.
| Δ α | α < t o l
Default = 10-8 (Real)
Example (Porous Soil)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  cm                 mus
#-  2. MATERIALS:
/MAT/LAW75/1/1
porous soil
#              RHO_I
                1.70
#                  E                  NU
                   3                .300
#  MAT_IDs    IFLAG1    IFLAG2    ITEMAX
         2         1         2         0
#                 PE                  PS                   N
                 .01                 .05                   0
#                TOL
                   0
/MAT/HYD_JCOOK/2/1
soil
#              RHO_I               RHO_O
          1.76000004                   0
#                  E                  nu
           3.5999999          .300000012
#                  a                   b                   n             eps_max           sigma_max
               10000                   0                   0                   0                   0
#                 C0                  C1                  C2                  C3
                   0                   0                   0                   0
#               Pmin                 Psh
                   0                   0
#                 C4                  C5                  E0
                   0                   0                   0
#                  c               EPS_0                   m               Tmelt               Tmax
                   0                   0                   0                   0                   0
#              RHOCP
                   0
/EOS/POLYNOMIAL/2/1
EOS for soil
#                 C0                  C1                  C2                  C3
                   0          2.81999993                   2               -1.37
#                 C4                  C5                  E0                 Psh
          1.53999996          1.53999996
#ENDDATAS
/END
  1. The porosity α is defined as:(1)
    α = ρ s ρ
    Note that α ≥ 1 ( ρ s ρ )
    Where,
    ρ s
    Density of the solid (full compacted matrix) material
    ρ
    Density of the porous material
  2. If the EOS of the solid (matrix) material is:(2)
    P = f ( ρ s , e )
    Then the EOS of the porous material is:
    P = f ( α ρ , e )
    for Herrmann formulation
    P = 1 α f ( α ρ , e )
    for modified Herrmann formulation
    Where, ( e ) is the internal energy per unit mass. It is same in porous material and in the solid (matrix) material.
  3. If P < P E the behavior is elastic, and if P > P E describes plastic region.
    In the elastic region, the change of porosity α with pressure P is reversible.
    In the plastic region, the porosity α is assumed to depend on pressure as described below:(3)
    α = 1 + ( α P 1 ) [ P S P P S P E ] n
    Where,
    α P
    Porosity where pressure reach the elastic compact pressure P E
    α = 1
    Pressure reaches the solid (matrix) compact pressure P S
    α 0
    Iinitial porosity
    mat_law75_porosity
1 "Constitutive equation for the dynamic compaction of ductile porous materials", Herrmann W., J. Applied Physics 40, 1969
2 "Static and dynamic pore collapse relations for ductile porous materials", Carroll M.M., Holt A.C., J. Applied Physics 43, 1972
