/PROP/PCOMPP
Block Format Keyword This property is used to define ply-based input.
/PROP/PCOMPP/prop_ID/unit_ID | |||||||||
prop_title |
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property
- The definition of the stacking sequence of
the elements with PCOMPP property is defined through the /STACK
and /PLY option.
All elements with PCOMPP prop_ID type must belong to a ply (/PLY) inside a stack (/STACK). See Example (Substack with /DRAPE) in /STACK.
