/PROP/TYPE17 (STACK)
Block Format Keyword This property set is used to define the sandwich shell property set using the stack and ply approach. Only one integration point can be defined for each ply.
There are two possible inputs:
  • All elements may have different number of plies by associating a group of elements to the ply in a way similar to OptiStruct.
  • The layout is described by a sequence of substacks ("SUB"), which are comprised of several plies. The interplay between substacks is defined with the keyword INT.
The input can be either "substack" or by ply, but not both.
/PROP/TYPE17/prop_ID/unit_ID or /PROP/STACK/prop_ID/unit_ID
prop_title
Ishell Ismstr Ish3n Idril Plyxfem   Z0
hm hf hr dm dn
  Istrain Thick Ashear   Ithick Iplas
VX VY VZ Skew_ID Iorth Ipos
By ply
Pply_IDi ϕ i Zi
Minterply
Or by substack
Sub Nsub Sub-plyn
Substack Name
Pply_IDi ϕ i Zi
Minterply
Sub Nsub Sub-plyn
Substack Name
Pply_IDj ϕ j Zj
Minterply
INT Pply_IDt Pply_IDb
prop_ID Property identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
prop_title Property title
Ishell Shell element formulation flag. 2
= 0
Use value in /DEF_SHELL.
= 1 Default, if /DEF_SHELL is not defined
Q4, visco-elastic hourglass modes orthogonal to deformation and rigid modes (Belytschko).
= 2
Q4, visco-elastic hourglass without orthogonality (Hallquist).
= 3
Q4, elasto-plastic hourglass with orthogonality.
= 4
Q4 with improved type 1 formulation (orthogonalization for warped elements).
= 12
QBAT shell formulation.
= 24
QEPH shell formulation.
(Integer)
Ismstr Shell small strain formulation flag. 3
= 0
= 1
Small strain from time =0 (new formulation compatible with all other formulation flags).
= 2 Default, if /DEF_SHELL is not defined
Full geometric nonlinearities with possible small strain formulation activation in Radioss Engine (option /DT/Eltyp/Keyword3/Iflag).
= 3
Old small strain formulation (only compatible with hourglass type 2).
= 4
Full geometric nonlinearities (in Radioss Engine, option /DT/SHELL/CST has no effect).
(Integer)
Ish3n 3 node shell element formulation flag.
= 0
= 1
Standard triangle (C0).
Standard triangle (C0) with modification for large rotation.
= 30
DKT18
= 31
DKT_S3, which based on DTK12 of BATOZ (refer to Element Library in the Theory Manual).
(Integer)
Idril Drilling degree of freedom stiffness flag. 8
= 0
No
= 1
Yes
(Integer)
Plyxfem Activates plyxfem formulation (beta version). 13
= 0
No
= 2
Yes
(Integer)
Z0 Distance from the shell element reference middle plane to the bottom surface of the ply (Real or blank). 10
It should be considered, if Ipos =2.
Default = 0.0 (Real)
hm Shell membrane hourglass coefficient. 4
Default = 0.01
Default = 0.01 for hourglass type 3 (Ishell = 3)
(Real)
hf Shell out-of-plane hourglass.
Default = 0.01 (Real)
hr Shell rotation hourglass coefficient.
Default = 0.01
(Real)
dm Shell Membrane Damping
Default = 5% for LAW25 and LAW27
Default = 1.5% for Ishell = 24 (QEPH) + LAW36
(Real)
dn Shell numerical damping. 5
Only used for Ishell = 12 and 24.
Default = 1.5% for Ishell =24 (QEPH)
Default = 0.1% for Ishell - 12 (QBAT)
Default - 0.01% for Ishell = 3- (DKT18)
(Real)
Istrain Compute strains for post-processing flag.
= 0
Yes
= 2
No
(Integer)
Thick Shell thickness. 10
(Real)
[ m ]
Ashear Shear factor.
Default is Reissner value: 5/6 (Real)
Ithick Shell resultant stresses calculation flag. 6
= 0
= 1
Thickness change is taken into account.
Thickness is constant.
(Integer)
Iplas Shell plane stress plasticity flag. 7
= 0
= 1
Radial return.
(Integer)
VX X component for reference vector. 9
Default = 1.0 (Real)
VY
Y component for reference vector.
VZ Z component for reference vector.
Skew_ID Skew identifier for reference vector. 9
If the local skew is defined, its X-axis replaces the global vector V . VX, VY, and VZ coordinates are ignored.
Default = 0 (Integer)
Iorth Orthotropic system formulation flag for reference vector.
= 0 (Default)
The first axis of orthotropy is maintained at constant angle with respect to the X-axis of an orthonormal co-rotational element coordinate system.
= 1
The first orthotropy direction is constant with respect to a non-orthonormal system of deformed element.
(Integer)
Ipos Ply positioning flag for reference vector. 10
= 0 (Default)
Ply positions are automatically calculated with regard to ply thicknesses. The coherence of global thickness with the sum of ply thicknesses is automatically checked.
= 1
All ply positions in the element thickness are user-defined. Multiple plies may have the same special position. Global thickness is not checked in this case, since it needs to not be equal to sum of ply thicknesses.
=2
The shell element reference plane is at Z0 from the bottom surface of the shell.
=3
The top surface of the shell is considered as element reference plane.
=4
The bottom surface of the shell is considered as element reference plane.
(Integer)
Sub =SUB: Indicates the beginning of a substack definition. 11
(Must be left justified)
(Integer)
Nsub Substack identification number.
(Integer)
Sub-plyn Number of plies in substack.
(Integer)
Substack Name Name of the substack.
(Maximum 100 characters)
Pply_IDi
Pply_IDj
Ply property identifier for ply i (j). Ply defned with /PROP/TYPE19.
(Integer)
i = 1, 2, 3 … 200
j = 1, 2, 3 … 200
Minterply Interply material identifier (needed only if plyxfem formulation is activated Plyxfem=2). 13
This material is ignored, if the plyxfem formulation is not activated (Plyxfem=0).
(Integer)
ϕ i
ϕ j
Angle for ply i (j). 9
(Real)
[ deg ]
Zi
Zj
Z position of ply i (j) (Zi or Zj defines the position of the middle of the ply).
[ m ]
Int =INT: Indicates the connection between 2 substacks (If used must be left justified).
(Integer)
Pply_IDt Ply identification number of the top ply of the bottom substack. One of ply_ID in Pply_IDi or Pply_IDj.
(Integer)
Pply_IDb Ply identification number of the bottom ply of the top substack. One of ply_ID in Pply_IDi or Pply_IDj.
(Integer)
Example (Ply with /DRAPE)
There are three plies in this example. Use /DRAPE to change the ply orientation so that each ply has a different material direction (fiber direction), and different material (which is defined in each ply with /PROP/TYPE19) is also applied.
prop_type17_ply_example
#RADIOSS STARTER
#-  1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for prop
#              MUNIT               LUNIT               TUNIT
                  kg                  mm                  ms
#-  2. GEOMETRICAL SETS:
/PROP/TYPE17/2/2
composite combine by substack
#   Ishell    Ismstr     Ish3n    Idrill   Plyxfem                            Z0
        12         0         0         1         0                             0
#                 hm                  hf                  hr                  dm                  dn
                   0                   0                   0                  .1                  .1
#            Istrain               Thick              Ashear              Ithick     Iplas
                   0                   0                   0                   1         1
#                 VX                  VY                  VZ   skew_ID     Iorth      Ipos
                   0                   1                   0         0         0         0
#      Sub      Nsub  Sub-plyn
SUB                1         4
Top substack
# Pply_IDi                PHIi                  Zi
        11                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        12                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        13                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        14                  90                   0
#Minterply
#      Sub      Nsub  Sub-plyn
SUB                2         4
Left substack
# Pply_IDi                PHIi                  Zi
        21                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        22                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        23                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        24                   0                   0
#Minterply
#      Sub      Nsub  Sub-plyn
SUB                3         4
Right substack
# Pply_IDi                PHIi                  Zi
        31                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        32                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        33                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        34                   0                   0
#Minterply
#      Sub      Nsub  Sub-plyn
SUB                4         3
Middle substack
# Pply_IDi                PHIi                  Zi
        41                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        42                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        43                  90                   0
#Minterply
#      Int  Pply_IDt  Pply_IDb
INT               14        21
INT               14        31
INT               43        21
INT               34        41
/PROP/TYPE19/11/2
PROP number 11
# mat_ID_i                   t           delta_phi id_grsh4n id_grsh3n   Npt_ply                 A_i
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/12/2
PROP number 12
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/13/2
PROP number 13
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/14/2
PROP number 14
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/21/2
PROP number 21
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/22/2
PROP number 22
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/23/2
PROP number 23
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/24/2
PROP number 24
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/31/2
PROP number 31
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/32/2
PROP number 32
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/33/2
PROP number 33
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/34/2
PROP number 34
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/41/2
PROP number 41
         1                  .5                  45        44         0         0                   0
/PROP/TYPE19/42/2
PROP number 42
         1                  .5                  45        44         0         0                   0
/PROP/TYPE19/43/2
PROP number 43
         1                  .5                  45        44         0         0                   0
#enddata
Example (Substack)
Substack definition for the ply layout.
prop_type17_example
#RADIOSS STARTER
/UNIT/2
unit for prop
#              MUNIT               LUNIT               TUNIT
                  kg                  mm                  ms
/PROP/TYPE17/2/2
        12         0         0         1         0                             0
#                 hm                  hf                  hr                  dm                  dn
                   0                   0                   0                  .1                  .1
                   0                   0                   0                   1         1
                   0                   1                   0         0         0         0
#      Sub      Nsub  Sub-plyn
SUB                1         4
Top substack
# Pply_IDi                PHIi                  Zi
        11                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        12                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        13                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        14                  90                   0
#Minterply
#      Sub      Nsub  Sub-plyn
SUB                2         4
Left substack
# Pply_IDi                PHIi                  Zi
        21                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        22                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        23                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        24                   0                   0
#Minterply
#      Sub      Nsub  Sub-plyn
SUB                3         4
Right substack
# Pply_IDi                PHIi                  Zi
        31                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        32                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        33                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        34                   0                   0
#Minterply
#      Sub      Nsub  Sub-plyn
SUB                4         3
Middle substack
# Pply_IDi                PHIi                  Zi
        41                  90                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        42                   0                   0
#Minterply
# Pply_IDi                PHIi                  Zi
        43                  90                   0
#Minterply
INT               14        21
INT               14        31
INT               43        21
INT               34        41
/PROP/TYPE19/11/2
PROP number 11
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/12/2
PROP number 12
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/13/2
PROP number 13
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/14/2
PROP number 14
         1                  .5                  45        45         0         0                   0
/PROP/TYPE19/21/2
PROP number 21
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/22/2
PROP number 22
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/23/2
PROP number 23
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/24/2
PROP number 24
         1                  .5                  45        46         0         0                   0
/PROP/TYPE19/31/2
PROP number 31
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/32/2
PROP number 32
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/33/2
PROP number 33
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/34/2
PROP number 34
         1                  .5                  45        47         0         0                   0
/PROP/TYPE19/41/2
PROP number 41
         1                  .5                  45        44         0         0                   0
/PROP/TYPE19/42/2
PROP number 42
         1                  .5                  45        44         0         0                   0
/PROP/TYPE19/43/2
PROP number 43
         1                  .5                  45        44         0         0                   0
#enddata
  1. The stack property is used in combination with /PROP/TYPE19 (PLY) to create composites properties through the ply-based definition.
    • The ply defined with /PROP/TYPE19 used in option Pply_IDi or Pply_IDj. in this stack property.
    • Only 1 integration point can be defined per ply i.e., Npt_ply =1 in /PROP/TYPE19 (PLY).
  2. Ishell, Ish3n – 4-node and 3-node shell formulation flag
    • Ishell = 1,2,3,4 (Q4): original 4 nodes Radioss shell with hourglass perturbation stabilization
    • Ishell = 24 (QEPH): formulation with hourglass physical stabilization for general use.
    • Ishell = 12 (QBAT): modified BATOZ Q4 y24 shell with four Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
    • Ish3n = 30 (DKT18): BATOZ DKT18 thin shell with three Hammer integration points.
    • The hourglass formulation is visco-elastic for Q4 shells.
  3. Ismstr - Small strain formulation
    • Small strain formulation is activated from time t = 0, if Ismstr = 1 or 3. It may be used for a faster preliminary analysis, but the accuracy of results is not ensured. Any shell for which Δ t < Δ t min can be switched to a small strain formulation by Radioss Engine option /DT/SHELL/CST, except if Ismstr = 4.
    • If the small strain option is set to 1 or 3, the strains and stresses which are given in material laws are engineering strains and stresses; otherwise they are true strains and stresses.
  4. hm, hf, and hr - Hourglass coefficients
    • hm, hf, and hr are only used for Q4 shells. They must have a value between 0 and 0.05.
    • For Ishell= 3, default values of hm and hr are 0.1 with larger values possible.
  5. dn - Shell numerical damping coefficient
    • Ishell = 12, 24:
      • for Ishell = 24, dn is used for hourglass stress calculation
      • for Ishell = 12 (QBAT), dn is used for all stress terms, except transverse shear;
      • for Ish3n = 30 (DKT18), dn is only used for membrane.
  6. Ithick - Shell resultant stresses calculation flag
    • If Ithick = 1, the small strain option is automatically deactivated in the corresponding type of element.
  7. Iplas - Shell plane stress plasticity flag
    • Iplas is available for material LAW27
    • It is recommended to use Iplas =1, if Ithick =1.
    • If Iplas =1, the small strain option is automatically deactivated in the corresponding type of element.
  8. Idril - Drilling degree of freedom stiffness flag
    • Drilling DOF stiffness is recommended for implicit solutions especially for Riks method and bending dominated problems.
    • Idril is available for QEPH, QBAT (Ishell = 12 or 24), and standard triangle (C0) shell elements (Ish3n= 1 or 2).
  9. Anisotropy in local coordinate system
    Two different ways to define the anisotropy direction with this property:
    Skew_ID=0
    Anisotropy direction defined with global vector V (components defined in Line 6) and angle ϕ i (angle in degree) for each ply.
    Skew_ID≠0
    Anisotropy direction defined with skew (X-axis in skew replaces the global vector V ) and angle ϕ i (angle in degree) for each ply.
    Projection of vector V (or x-axis of skew)on shell element plane becomes the vector V . Then for each ply, the first anisotropic direction (direction 1) is vector V is turned ϕ i degrees; where, positive rotation is based on the shell normal n .
    prop_type9_v10
    Figure 3.
    α i
    The angle between local anisotropic direction 1 and 2 (directions of anisotropy) for each ply which defined in /PROP/TYPE19.
    In case of reference metrics, the orientation for directions of anisotropy must be defined with the reference geometry, not the initial one.
  10. Ipos - ply position
    • In this property, ply position defined with Zi and option Ipos.
    • Zi values are real ply positions in the local Z axis (negative and positive value are allowed and Zi defines the position of the middle of each ply).
    • Z0 only used with Ipos=2, it indicated distance from the shell element reference middle surface to the bottom surface of the whole ply or stack. For more information, see Ipos=2
    • Ipos= 0: ply positions are automatically calculated with regard to ply thicknesses.
      • The input thickness “Thick” may be equal to zero as the true shell thickness is always calculated from the ply thicknesses and positions of ply defined by Zi.
      • If the input thickness “Thick” is different from 0.0, a warning will be displayed if the calculated thickness from the plies is different from the input thickness.
        Ipos_0
        Figure 4.
    • Ipos= 1: All ply positions and thickness in the element are user-defined (with t i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDamaaBa aaleaacaWGPbaabeaaaaa@380A@ in /PROP/PLY and Zi).
      • Global thickness “Thick” is not checked, as it does not need to be equal to the sum of ply thickness.
      • Multiple plies are allowed to have the same space position.
      • This option is not recommended unless the number of ply is constant for all elements.
    • Ipos= 2: the shell element mid-surface is at Z0 from the bottom of the ply layout.
      Figure 5.
    • Ipos = 3: the top of the ply layout is coincident with the element mid-surface
      Figure 6.
    • Ipos = 4: the bottom of the ply layout is coincident with the element mid-surface
      Figure 7.
  11. Define by substack
    • If the substack definition is used, each substack definition begins with the keyword “SUB” and the substack identification number.
    • All the plies until the next keyword “SUB” or the keyword “INT” is encountered belong to the same substack.
    • All substacks must be defined before defining the “INT” connections.
    • If an element contains plies belonging to several substacks, the connection between the substacks is defined with an “INT” connection: the ply Pply_IDt of the first substack is connected to the ply Pply_IDb of the second substack.
    • For more details, refer to the above examples for this property.
  12. Material for each ply
    • Material for each ply defined with mat_ID in /PROP/TYPE19.
    • Material between each ply defined with Minterply inside this property. It used for Plyxfem formulation.
    • This property is only compatible with Material Laws 25, 27, 36, 60, 72, 93 and user laws.
    • Material law type for ply must be the same for each ply
    • The material law number given in /PART will be used to define the mass and the sound speed of the composite, as well as the interface stiffness.
    • The material law type input in the /PART definition must be identical to the material law type used in mat_ID in /PROP/TYPE19.
  13. Plyxfem formulation
    • The plyxfem formulation is activated using the Plyxfem flag. It used to describe the delamination between plies.
    • Once plyxfem is activated (Plyxfem=2) then an interply material (Minterply) must be defined between each ply.
    • This interply material must use LAW1 with Ladeveze failure criteria (/FAIL/LAD_DAMA) for delamination.
    • This option is in the beta stage.
