/PROP/TYPE20 (TSHELL)
Block Format Keyword This property is used to define the general thick shell property set.
/PROP/TYPE20/prop_ID/unit_ID or /PROP/TSHELL/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Isolid | Ismstr | Icstr | Inpts | Iint | dn | ||||
qa | qb | h | |||||||
Istrain |
prop_ID | Property
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
prop_title | Property
title. (Character, maximum 100 characters) |
Isolid | Solid elements formulation flag.
(Integer) |
Ismstr | Strain formulation flag.
3
(Integer) |
Icstr | Constant stress
formulation flag to indicate the thickness direction. Only valid for
Isolid =14. 2
(Integer) |
Inpts | Number of integration
points.
(Integer) Where:
Iint | Thickness integration
formulation. Only valid for Isolid =16.
(Integer) |
dn | Numerical damping for
stabilization. Only valid for Isolid =15. Default = 0.1 (Real) |
qa | Quadratic bulk
viscosity. Default = 1.10 (Real) Default = 0.0 for /MAT/LAW70 (FOAM_TAB) |
qb | Linear bulk
viscosity. Default = 0.05 (Real) Default = 0.0 for /MAT/LAW70 |
h | Hourglass viscosity
coefficient. Default = 0.10 (Real) |
Minimum time
step Default = 106 (Real) |
Istrain | Compute strain
post-processing flag. 7
(Integer) |
- Thickness direction:
- By default, the element must be oriented so that the thickness direction of the thick shell is in the elements "s" direction.
- However, when using Isolid=14 (HA8), a
different thickness direction can be specified using the constant stress
flag, Icstr. Note: Check the elements local system orientation using a pre-processor.
- r, s, t
- Isoparametric frame
- r
- Center of (1, 2, 6, 5) to center of (4, 3, 7, 8)
- s
- Center of (1, 2, 3, 4) to center of (5, 6, 7, 8)
- t
- Center of (1, 4, 8, 5) to center of (2, 3, 7, 6)
- Icstr - for reduced stress
integration.For Isolid=14 (HA8) the reduced integration direction and thus thickness direction of the shell can be set by parameter Icstr. This parameter represents a 3-digit sequence of "0" and "1", which corresponds to standard r-s-t elemental coordinate system for solid elements.
- 0
- No reduced stress integration is done in corresponding direction.
- 1
- Reduced integration is used in this direction.
For example:
"010" means that reduced integration is used and the thickness direction corresponds to element axis "s".
- Isolid - Solid elements
formulation flag.
- For Isolid=15, parameter Icstr has no effect. It is always assumed that elemental direction "s" uses reduced integration and is the thickness direction.
- When property is used with /MAT/LAW1 (ELAST), with Isolid =15 and number of integration points is different from one, number of integration points is set to 2 (enough to compute correct bending).
- When using Isolid=15 with pentahedron elements, /PENTA6 elements are recommended but degenerated /BRICK elements can also be used.
- Ismstr
- Small strain formulation flag.
- If the small strain option is set (Ismstr =1, 3), the strains and stresses used in material laws are engineering strains and stresses. Otherwise, they are true strains and stresses.
- The small strain option is available for Isolid =14 (HA8) and Isolid =15 (HSEPH).
- The Radioss Engine option /DT/BRICK/CST will only work for brick property sets with Ismstr =2
- Starting with version 2017, Lagrangian elements whose volume becomes
negative during a simulation will automatically switch strain
formulations to allow the simulation to continue. When this occurs, a
WARNING message will be printed in the Engine output file. The following
options are supported.
Element Type Element Formulation Strain Formulation Negative Volume Handling Method /BRICK Isolid =14, 15 Full geometric nonlinearities Ismstr = 2, 4
Switch to small strain using element shape from cycle before negative volume.
- Numerical damping dn is only used in hourglass stress calculation for HSEPH (Isolid =15).
- Hourglass viscosity coefficient h must have a value between 0 and 0.15 and is not active with 8 integration point solids.
- Output for
post-processing.
- The Istrain flag is not used with Material Laws 14, 24 and Material Laws greater than 28. For these materials, the strains for post-processing are always computed.
- For post-processing solid element stress, refer to /ANIM/STRESS for animation and /TH/BRICK for plot files.
