/DEF_SOLID
Block Format Keyword This keyword is used to set default values for certain parameters in all solid properties and thick shells. The default values defined here will be overwritten by any values entered on the individual property input.
/DEF_SOLID | |||||||||
Isolid | Ismstr | Istrain | Itetra4 | Itetra10 | Imas | Iframe |
Isolid | Solid elements formulation
flag. 2
(Integer) |
Ismstr | Small strain formulation
flag. 3
(Integer) |
Istrain | Computes strains for
post-processing flag
(Integer) |
Itetra4 | 4 node tetrahedral element
formulation flag.
(Integer) |
Itetra10 | 10 node tetrahedral
element formulation flag.
(Integer) |
Imas | Nodal mass distribution
(per element) flag. Only for tetra4 and tetra10 element.
(Integer) |
Iframe | Element coordinate system
formulation flag. only for standard 8-node bricks: Isolid=1, 2 or 17.
(Integer) |
- This card is read only once. Only the first card /DEF_SOLID written in the model is used. The other card /DEF_SOLID is ignored.
- Refer to the comments in /PROP/SOLID for more information about these input options.
