/RBODY/LAGMUL
Block Format Keyword Defines rigid bodies using Lagrange multipliers. This keyword is not available for SPMD computation.
/RBODY/LAGMUL/rbody_ID/unit_ID | |||||||||
rbody_title | |||||||||
node_ID | grnd_ID | ||||||||
Blank Format | |||||||||
node_ID1 | node_ID2 | node_ID3 | node_ID4 | node_ID5 | node_ID6 | node_ID7 | node_ID8 | node_ID9 | node_ID10 |
rbody_ID | Rigid body
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
rbody_title | Rigid body
title. (Character, maximum 100 characters) |
node_ID | Master (primary) node
identifier. (Integer) |
grnd_ID | Slave nodes group
node_ID1, node_ID2,...,node_ID10 | List of slave node
identifiers. (Integer) |
- The master (primary) and slave nodes must have non-zero mass and inertia.
- The master (primary) node is not moved to the center of gravity of the body.
- All nodes are equivalent (no distinction between master and slave nodes in this formulation) and may have other kinematical conditions of Lagrange Multiplier type.
