Add Representations From the Subsystem Library
Subsystem representations can be added from external sources such as a subsystem library.
  1. In the Subsystem Browser, right-click on a subsystem(s) and select Representations > Add > from Library from the context menu.
    The Add Representations from Library dialog opens.
  2. In the Add Representation from Library dialog, select the representations to add.
  3. Optional: To simultaneously add and load representations, select the representations to load from the Load Added Representations list.
  4. Click OK.
