Delete Representations From the Part Library
Subsystem representations can be deleted from the Part library.
  1. In the Subsystem Browser, right-click on a subsystem(s) and select Representations > Delete > from Library from the context menu.
    The Delete Representations from Library dialog opens.
  2. In the Delete Representations from Library dialog, selected the representations you want to delete.
  3. Click OK.
