Load Representations From Current HyperMesh Session
Subsystem representations can be loaded from the current HyperMesh session.
  1. In the Subsystem Browser, right-click on a subsystem(s) and select Representations > Load > from Session from the context menu.
    The Load Representation dialog opens.
  2. In the Load Representation dialog, Load tab, select a type of representation to load.
    Representations that exist in the repository are shown in the Representations column, and their availability is indicated in the Available column.
