OS-V: 0040 Z-Section Cantilever
Test No. LE5 OptiStruct examines the axial (x-x) stress (compression) at mid-surface, point A for linear static analysis.
![](../../../images/solvers/nafems_z_section_cantilever.png)
Benchmark Model
Quad4 and Quad8 elements are used to create a uniform mesh of 8 elements along the length with one element across width of flange. All the displacements at one end are maintained zero, at the other end two uniformly distributed force of 0.6MN each are applied.
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
Linear Static Analysis Results
Quadrilateral Shells | Axial Stress (x-x) at Mid-surface Point A (MPa) | Normalized with the Target Value |
Quad4 | -112.2 | 0.962566845 |
Quad8 | -110.9 | 0.973850316 |
Model Files
The model files used in this problem include:
- /LE5Quad4.fem
- /LE5Quad8.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
