poIMeasure GetFromSetType
Gets the "from" selection set type.
poIMeasure_handle GetFromSetType item_index
HyperView Tcl Query
This command will return the type of the entity set used for the "from" selection.
- item_index
- The index of the measure item within the group.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page page_id
page GetWindowHandle window win_id
window GetClientHandle post
post GetMeasureHandle mindist measure_id
mindist GetFromSetType item_index
Returns the type (Part/Element/Node) if successful, otherwise an error code.
