poIMeasure SetResultSystem
Sets the measure analysis system.
poIMeasure_handle SetResultSystem sys_id
HyperView Tcl Modify
This command sets the measure analysis system.
- sys_id
- The system ID in form: 'model_id system_id', you can omit model_id - current model will be used to use tracking system specify -3.
Returns 0 if successful, otherwise an error code.
