poIMeasure HighlightEntitySet
Highlights the "from" and "to" selections for the measure item.
poIMeasure_handle HighlightEntitySet item_index
HyperView Tcl Modify
This command will will highlight the entity sets for the particular measure item. The “from” selection will be highlighted in green and the “to” selection will be highlighted in white.
Note: The Review mode for the measure group must be set to “true”.
item_index
The index of the measure item within the group.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page page_id
page GetWindowHandle window win_id
window GetClientHandle post
post GetMeasureHandle mindist measure_id
mindist HighLightEntitySet 2
Returns 0 if successful, otherwise an error code.
