General Solver Deck Export Options
General options used across solver interfaces to determine how FE models are exported.
General
- Export
- Type of entities to export.
- Template
- Select the appropriate template file type.
- Include export
- Method for exporting includes.
- Write Connectors
- Export all of the connectors in the model. This operation appends the master connector file xml data to the end of the solver input file as solver comments and thus does not effect the operation of the solver. This operation can remove the necessity to perform a FE-absorb on a imported model since the connector information is retained in the solver input file.
- Write ID rules
- Export ID management rules defined in the ID Manager as an XML block at
the end of each Include file. Restriction: Available when Include export is set to Preserve.
Write comments for
- HyperMesh
- Write HyperMesh comments upon export. When unchecked, HyperMesh comment cards are ignored.
- Part Assemblies/Parts
- Export an xml comment block containing HyperMesh part assemblies/parts, along with PDM metadata.
- Materials
- Write comments for materials.
Warning Messages
- Invalid elements
- Display warning message upon invalid elements.
- Overwrite existing file
- Display warning message upon overwriting an existing file.
- ID Overflow
- Display warning message upon ID overflow.
