The MotionView Tools menu allows you to check a model for errors, select a writer and user mode, and access such panels as Reports,
Templex Functions, and Options.
Check Model searches for unresolved references and invalid data in the model. If errors in the model are detected,
it is reported in the message window that is displayed when the check is completed.
Invokes the Model Identification Tool. This tool can be used to fit experimental data to analytical models for frequency,
amplitude, and preload dependent bushings.
A metadata file is automatically generated when you save the active MDL model as an ADAMS or MotionSolve deck or you
run a solver analysis on the active model.
The Check Model options allow you to select which information from the model file will
be displayed when the Check Model tool is run.
To open this dialog, select Options from the Tools menu, and then
click Check Model on the tree.
Figure 1. Options dialog – Check Model
Activate the check box next to one of the available options (listed below) to include this
information in the Check Model dialog (which is displayed after the
check of the model is completed). The information for each activated option will be
displayed in its own tab.
Error Messages
Warning Messages
Check Model on opening
General Model Information
Degrees of Freedom
Files used by Model
Suspect Data
Use entity labels in messages
Note: The Error Message and Warning Messages options are
automatically displayed in the Message Log and will always be active, therefore these
options have been disabled in this dialog.
Activate the Check Model on
opening option to have MotionView run a "check
model" immediately upon opening any model file.
