/PROP/TYPE25 (SPR_AXI)
Block Format Keyword This property set is used to define the axisymmetric spring property set.
/PROP/TYPE25/prop_ID/unit_ID or /PROP/SPR_AXI/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Mass | Inertia | Skew_ID | sens_ID | Isflag | Ifail | Ileng | Ifail2 |
K1 | C1 | A1 | B1 | D1 | |||||
fct_ID11 | H1 | fct_ID21 | fct_ID31 | F1 | |||||
Ascale1 | E1 | fct_ID41 | Hscale1 |
K2 | C2 | A2 | B2 | D2 | |||||
fct_ID12 | H2 | fct_ID22 | fct_ID32 | F2 | |||||
Ascale2 | E2 | fct_ID42 | Hscale2 |
K3 | C3 | A3 | B3 | D3 | |||||
fct_ID13 | H3 | fct_ID23 | fct_ID33 | F3 | |||||
Ascale3 | E3 | fct_ID43 | Hscale3 |
K4 | C4 | A4 | B4 | D4 | |||||
fct_ID14 | H4 | fct_ID24 | fct_ID34 | F4 | |||||
Ascale4 | E4 | fct_ID44 | Hscale4 |
C1 | n1 | ||||||||
C2 | n2 | ||||||||
C3 | n3 | ||||||||
C4 | n4 |
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property
Mass | Spring
mass (Real) |
Inertia | Spring
inertia (Real) |
Skew_ID | Skew system
identifier (Integer) |
sens_ID | Sensor
Isflag | Sensor flag.
(Integer) |
Ifail | Failure criteria.
(Integer) |
Ileng | Input per unit length
flag.
(Integer) |
Ifail2 | Failure model flag.
(Integer) |
K1 | Stiffness for
tension (Real) |
C1 | Damping for
tension (Real) |
A1 | Coefficient for strain
rate effect in tension (homogeneous to a force). Default = 1.0 (Real) |
B1 | Logarithmic coefficient
for strain rate effect in tension (homogeneous to a
force). (Real) |
D1 | Scale coefficients for
elongation velocity. Default = 1.0 (Real) |
fct_ID11 | Function identifier
defining
If H1 =4: Upper yield curve function identifier (Integer) |
H1 | Hardening flag.
(Integer) |
fct_ID21 | Function identifier
defining
. (Integer) |
fct_ID31 | Function used only for
unloading. If H1=4: Function identifier defining lower yield curve. If H1=5: Function identifier defining residual displacement vs maximum displacement. If H1=6: Function identifier defining nonlinear unloading curve. If H1=7: Function identifier defining nonlinear unloading curve. (Integer) |
fct_ID41 | Function identifier
defining
. (Integer) |
Hscale1 | Coefficient for
(homogeneous to a force). Default = 1 (Real) |
F1 | Scale factor for
in function
. (Real) |
Negative failure
limit. Default = -1030 (Real) |
Positive failure
limit. Default = 1030 (Real) |
Ascale1 | Abscissa scale factor for
(fct_ID11 and fct_ID31). (Real) |
E1 | Coefficient for strain
rate in tension (homogeneous to a force). (Real) |
K3 | Stiffness for
torsion. (Real) |
C3 | Damping for
torsion. (Real) |
A3 | Coefficient for strain
rate effect in torsion (homogeneous to a moment). Default = 1.0 (Real) |
B3 | Logarithmic coefficient
for strain rate effect in torsion (homogeneous to a
moment). (Real) |
D3 | Scale coefficients for
torsion velocity. Default = 1.0 (Real) |
fct_ID13 | Function identifier
defining
If H3=4: Function identifier defining upper yield curve (Integer) |
H3 | Hardening flag.
(Integer) |
fct_ID23 | Function identifier
defining
. (Integer) |
fct_ID33 | Function used only for
unloading. If H3=4: Function identifier defining lower yield curve. If H3=5: Function identifier defining residual displacement vs maximum displacement. If H3=6: Function identifier defining nonlinear unloading curve. If H3=7: Function identifier defining nonlinear unloading curve. (Integer) |
fct_ID43 | Function identifier
defining
. (Integer) |
Hscale3 | Coefficient for
F3 | Scale factor for
in function
. (Real) |
Negative failure
Positive failure
Ascale3 | Abscissa scale factor for
(fct_ID13 and fct_ID33). (Real) |
E3 | Coefficient for strain
rate effects in torsion (homogeneous to a
moment). (Real) |
K2 | Stiffness for
shear. (Real) |
C2 | Damping for
shear. (Real) |
A2 | Coefficient for strain
rate effect in shear (homogeneous to a force). Default = 1.0 (Real) |
B2 | Logarithmic coefficient
for strain rate effect in shear (homogeneous to a force). Default = 1.0 (Real) |
D2 | Scale coefficients for
shear velocity. Default = 1.0 (Real) |
fct_ID12 | Function identifier
defining
If H2=4: Function identifier defining upper yield curve (Integer) |
H2 | Hardening flag.
(Integer) |
fct_ID22 | Function identifier
defining
. (Integer) |
fct_ID32 | Function used only for
unloading
. If H2=4: Function identifier defining lower yield curve. If H2=5: Function identifier defining residual displacement vs maximum displacement. If H2=6: Function identifier defining nonlinear unloading curve. If H2=7: Function identifier defining nonlinear unloading curve. (Integer) |
fct_ID42 | Function identifier
defining
. (Integer) |
Hscale2 | Coefficient for
F2 | Scale factor for
in function
. (Real) |
Negative failure
Positive failure
E2 | Coefficient for strain
rate effect in shear (homogeneous to a force). (Real) |
Ascale2 | Abscissa scale factor for
(fct_ID12 and fct_ID32). (Real) |
K4 | Stiffness for
bending. (Real) |
C4 | Damping for
bending. (Real) |
A4 | Coefficient for strain
rate effect in bending (homogeneous to a moment). Default = 1.0 (Real) |
B4 | Logarithmic coefficient
for strain rate effect in bending (homogeneous to a
D4 | Scale coefficients for
bending velocity. Default = 1.0 (Real) |
fct_ID14 | Function identifier
defining
If H4=4: Function identifier defining upper yield curve. (Integer) |
H4 | Hardening flag.
(Integer) |
fct_ID24 | Function identifier
defining
. (Integer) |
fct_ID34 | Function used only for
unloading. If H4=4: Function identifier defining lower yield curve. If H4=5: Function identifier defining residual displacement vs maximum displacement. If H4=6: Function identifier defining nonlinear unloading curve. If H4=7: Function identifier defining nonlinear unloading curve. (Integer) |
fct_ID44 | Function identifier
defining
. (Integer) |
Hscale4 | Coefficient for
F4 | Scale factor for
in function
. (Real) |
Negative failure
Positive failure
Ascale4 | Abscissa scale factor for
(fct_ID14 and fct_ID34). (Real) |
E4 | Coefficient for strain
force). (Real) |
Reference translational
Reference rotational
C1 | Relative velocity
coefficient in translation X. Default = 0.0 (Real) |
n1 | Relative velocity exponent
"Mult" factor in
translation X. Default = 1.0 (Real) |
Exponent in translation
X. Default = 2.0 (Real) |
C2 | Relative velocity
coefficient in shear. Default = 0.0 (Real) |
n2 | Relative velocity exponent
"Mult" factor in
shear. Default = 1.0 (Real) |
Exponent in
shear. Default = 2.0 (Real) |
C3 | Relative velocity
coefficient in torsion X. Default = 0.0 (Real) |
n3 | Relative velocity exponent
"Mult" factor in torsion
Exponent in torsion
C4 | Relative velocity
coefficient in bending. Default = 0.0 (Real) |
n4 | Relative velocity exponent
"Mult" factor in
bending. Default = 1.0 (Real) |
Exponent in
bending. Default = 2.0 (Real) |
- The
spring's X direction is defined using nodes N1 and N2 of the spring.
- If the node of the spring N3 is defined, the spring's Y direction is defined
using nodes N1 and N3 of the spring. N3, N2, and N1 should not be in a line.
The Z direction is:
(1) - If node N3 is not defined in the element input, and skew system is defined
in the property input, the Z direction is:
(2) - If neither node N3 nor skew system are defined in input, the Z direction
is:
(3) - Finally, Y direction is found as:
(4)
The Z direction is:
- In case of
Ileng =0, the force in the spring
is computed as:
Linear spring:
with =1, 2
with = 3, 4
Nonlinear spring:
with i= 1, 2
with i= 3, 4
withNote:- Here, (with ) is the difference between the current length and the initial length of the spring element for corresponding translational DOF.
- is the relative angle for corresponding rotational DOF in radians.
- For linear springs, , and , , and are null functions and Ai, Bi, Ei, and Hscalei are not taken into account.
- If stiffness function (or ) is requested, then K is used as a slope for unloading only.
- If K is lower than the maximum slope of function (or ) (K is not consistent with the maximum slope of the curve), K is set to the maximum slope of the curve.
- If Ileng = 1, all input are per
unit length:
- Spring mass =
Spring stiffness =
Spring damping =
Spring inertia =
Where, is the reference spring length.
- The force in the spring is computed as:
Linear spring:
with =1, 2
with =3, 4
Nonlinear spring:
with =1, 2
with =3, 4
Where, is the engineering strain and defined as:(5) Force functions are given versus engineering strain and engineering strain rate.
Failure criteria are defined with respect to strain. Input negative/positive failure limit should be related to initial length
- Spring mass =
Spring stiffness =
Spring damping =
Spring inertia =
- If hardening flag is 4, hardening is kinematic. Lower and upper yield curves are the same.
- If hardening flag is 5,
residual deformation is a function of maximum displacement:
with =1,2
with =3,4
- The decoupled hardening (hardening flag Hi=2) and kinematic hardening (hardening flag Hi=4) models are only valid in axial direction (tension and torsion). They are not available in radial direction (shear and bending).
- Failure criteria:
- If the failure criteria are uni-directional Ifail=0, the spring fails
as soon as one of the criteria is met in one direction:
or , with and being the failure limits in direction =1, 2
or , with and being the failure limits in direction =3, 4
For each direction (or ) should be negative and (or ) should be positive. If the values are zero, then no failure will be taken into account.
- If the failure criteria is multi-directional Ifail=1, the spring fails
when the following criteria is fulfilled:
(6) For "old" displacement formulation (Ifail =0), the coefficients and i are equal to 1.0 and 2.0, respectively.
New formulation ( Ifail2 > 0) allows to model velocity dependent failure limit for translational DOF:(7) Where, or is the static failure limit in translational directions (Lines 5 and 8), and is the reference velocity.
- Force and energy criteria are activated with
Ifail2=2 or
3:
(8) In this case the displacement values are replaced by positive failure force or failure energy values.
New formulation (Ifail2 =1) allows you to model velocity dependent failure limit for rotational DOF:(9) Where, or is the static failure limit in rotational direction (Lines 11 and 14), and 0 is the reference velocity.
Moment and energy criteria are activated with Ifail2=2 or 3:(10) In this case the rotation values are replaced by positive failure moment or failure energy values.
- Spring
activated and/or deactivated by sensor:
- If sens_ID ≠ 0 and Isflag = 0, the spring element is activated by the sens_ID.
- If sens_ID ≠ 0 and Isflag = 1, the spring element is deactivated by the sens_ID.
- Spring elements with sensor activation or deactivation are mainly used for the pretension model.
- If a sensor is used for activating or deactivating a spring, the reference length of the spring at sensor activation (or deactivation) is equal to the nodal distance at time =0.
