/PROP/TYPE32 (SPR_PRE)
Block Format Keyword This property describes the pretension spring property set that can be used to model seat belt pretensioners or apply pretension to a bolt.
/PROP/TYPE32/prop_ID/unit_ID or /PROP/SPR_PRE/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
M | sens_ID | Ilock | |||||||
fct_ID1 | fct_ID2 |
prop_ID | Property identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property title (Character, maximum 100 characters) |
M | Spring mass (Real) |
sens_ID | Sensor
identifier (Integer) |
Ilock | Lock feature flag.
(Integer) |
Spring stiffness before sensor
activation, unloading stiffness after sensor activation, and spring stiffness after
the spring has locked. (Real) |
Force at sensor
activation (Real) |
Piston's slide
length (Real) |
Initial internal energy at sensor
activation (Real) |
Loading stiffness after sensor
activation. (Real) |
fct_ID1 | Loading force function vs displacement
. (Integer) |
fct_ID2 | Loading force function vs time after
sensor activation
. (Integer) |
Example (Pretension)
#RADIOSS STARTER
#- 1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for prop
# MUNIT LUNIT TUNIT
kg m s
/PROP/SPR_PRE/11/2
PRETENSIONER
# M sens_ID Ilock
.05 1 0
# Stif0 F1 D1 E1 Stif1
100000 0 .25 0 0
# fct_ID1 fct_ID2
1 0
/SENSOR/TIME/1
pretentioner
# Tdelay
0.1
/FUNCT/1
Loading force function vs displacement after sensor activation
# X Y
-1 0
-.1 95
0 100
#ENDDATA
- Pretension elements are /SPRING elements with two nodes. These elements can be used to model seat belt pretensioners or apply pretension to a bolt.
- The pretension element can be visualized as a piston with slide length that moves to create the pretension force.
- The pretension element force
starts after sensor activation and can be defined using a linear or nonlinear force:
- The linear model is defined by entering any two of these parameters; force at
activation (
), piston slide length (
), initial internal energy (
), and loading stiffness (
The other two parameters are calculated using:
and(1)
- The nonlinear model is defined by entering curves as a function of displacement, fct_ID1 or as a function of time, fct_ID2. If either function is used the previous input for
and
are ignored. The pretension force is then defined
as:
- Time at sensor activation
- Length at sensor activation with
activation (
- If slide length is defined, then the pretension force is set to zero and spring is locked when the spring shortens in length by the slide length .
- If Ilock = 1, the spring is locked when the spring shortens by the slide length or the pretension force is zero as defined by the force functions fct_ID1 or fct_ID2:
- If
Ilock=2, the spring is locked after any
unloading.Lock examples for force versus displacement, fct_ID1 but also valid for force versus time fct_ID2
- After the spring is locked, the spring stiffness is .
- The pretension spring can become unstable if the length of the spring approaches zero.
- Elongation output, LX, LY, LZ from /TH/SPRING is elongation velocity.
- If used for bolt
pretensioning:
- A duplicate spring with /PROP/SPR_BEAM should be used to model 2 – 6 degrees of freedom of the bolt.
- Use Ilock=1, and define fct_ID2 with zero force at the end of the pretensioning time to lock the spring.
