/TH/INTER
Block Format Keyword Describes the time history for interfaces.
/TH/INTER/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
thgroup_ID | TH
group identifier. (Integer, maximum 10 digits) |
thgroup_name | TH
group name. (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for
TH (see table below). (Character, maximum 8 characters) |
Obj_ID1, ...n | Identifiers of the objects
to be saved. (Integer) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
INTER | Interface | FNX, FNY,
FNZ, FTX,
FTY, FTZ, and
SFW. |FNX|, |FNY|, |FNZ|, ||FN||, |FX|, |FY|, |FZ|, ||F||, MX, MY, MZ These absolute force variables are only for interface types /INTER/TYPE7, /INTER/TYPE10, /INTER/TYPE11, /INTER/TYPE19 and their sub interfaces (/INTER/SUB). QFRIC is available for interface TYPE7 and TYPE21. |
Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
INTER | DEF FN FT |FN| |F| Qfric |
FNX, FNY,
FNZ, FTX,
FTY,
FTZ FNX, FNY, FNZ FTX, FTY, FTZ |FNX|, |FNY|, |FNZ|, ||FN|| |FX|, |FY|, |FZ|, ||F|| QFRIC |
Output for Interface
- SFW is the work of forces along the interface. It is only available for interfaces type 14 and 15.
- FNX: normal force in direction X
- FNY: normal force in direction Y
- FNZ: normal force in direction Z
- FTX: tangent force in direction X
- FTY: tangent force in direction Y
- FTZ: tangent force in direction Z
- |FNX| absolute value of normal force of the X-component of the contact force
(1) is the X-component of the normal contact force applied to the master segment , due to slave node .
- |FNY|: absolute value of normal force of the Y-component of the contact force
- |FNZ|: absolute value of normal force of the Z-component of the contact force
- |FX|: absolute value of the X-component of the contact force
(2) is the X-component of the contact force applied to the master segment , due to slave node .
- |FY|: absolute value of the Y-component of contact force
- |FZ|: absolute value of the Z-component of contact force
- MX: moment around X-axis of global system
- MY: moment around Y-axis of global system
- MZ: moment around Z-axis of global system
- QFRIC: heat created from friction energy
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- Energy created by interface friction is included in the global contact energy output.
