Use the Edit: Replace tool
to relocate and replace the positions of nodes.
The Edit tools work for tessellated
geometry. If the input is b-spline geometry, first convert to discrete geometry
using the Convert tool.
From the Geometry ribbon, FE Geometry tools, click .
Elements are colored according to how
well they adhere to the pre-set quality requirements defined in the criteria
file.
Select an element issue type from the guide bar.
- Quality
- Checks for quality as defined in quality criteria.
- Intersections
- Checks for intersecting elements.
- Face angles
- Checks for folded or sharp angle elements.
- Optional:
Find all elements at or below a certain quality level.
Click Find on the guide bar.
Increase or decrease the number of layers around patches of failed
elements by clicking
or
on the guide bar.
Review the next or previous patch of failed elements by clicking
or
on the guide bar.
Select a replacement method from the guide bar then
select nodes/ element edges.
Method |
Node Replacement Steps |
One to One |
- Select a node to relocate and replace.
- Select a target node.
The second node replaces the
first.
Note: You can also perform one to one replacement by selecting an
element edge to collapse. Selecting an element edge automatically
performs midpoint replacement.
Multi to One |
- Select multiple nodes.
- From the selected nodes, left-click on a single target
node.
All other nodes are relocated to and replaced by
this node.
Multi to Multi |
- Repeat this process as many times as desired.
- Left-click on a target node or click
Replace on the guide bar to replace all nodes at once.
