Additional Parameters for the MF2002 Variant
The following is a list of additional parameters for the Magic Formula 2002 variant:
Section [PARAMETER] or [VERTICAL]
In this section, one additional data item is searched for in the case of the 2002 variant:
Name in input file Unit Required Default value Explanation
longvl length/time Yes - Reference velocity, used in rolling resistance torque computation
Section [LONG_SLIP_RANGE]
This section specifies bounds for the effective longitudinal slip as it is used in the MF 2002 equations:
kpumin - No -1 Lower bound fort effective longitudinal slip
kpumax - No 1 Upper bound fort effective longitudinal slip
Section [SLIP_ANGLE_RANGE]
This section specifies bounds for the effective slip angle as it is used in the MF 2002 equations:
alpmin angle No -1 rad Lower bound fort effective longitudinal slip
alpmax angle No 1 rad Upper bound fort effective slip angle
Section [INCLINATION_ANGLE_RANGE]
This section specifies bounds for the effective camber angle as it is used in the MF 2002 equations:
cammin angle No -0.2 rad Lower bound fort effective camber angle
cammax angle No 0.2 rad Upper bound fort effective camber angle
Section [VERTICAL_FORCE_RANGE]
This section specifies bounds for the effective wheel load as it is used in the MF 2002 equations:
fzmin force No 0 N Lower bound fort effective wheel load
fzmax force No 10000 N Upper bound fort effective wheel load
Section [LATERAL_COEFFICIENTS]
This section specifies the MF 2002 side force parameters:
pcy1 .. pty2 - Yes - pcy1 to pty2, cf. [PAC], p. 614
Section [LONGITUDINAL_COEFFICIENTS]
This section specifies the MF 2002 longitudinal force parameters:
pcx1 .. ptx3 - Yes - pcx1 to ptx3, cf. [PAC], p. 614
Section [ALIGNING_COEFFICIENTS]
This section specifies the MF 2002 aligning torque parameters:
qbz1 .. qtz1 - Yes - qbz1 to qtz1, cf. [PAC], p. 614
mbelt mass Yes - Belt mass
Section [ROLLING_COEFFICIENTS]
This section specifies the MF 2002 parameters for rolling resistance torque:
qsx1 .. qsx3 - Yes - qsx1 to qsx3, cf. [PAC], p. 614
Section [OVERTURNING_COEFFICIENTS]
This section specifies the MF 2002 parameters for overturning torque:
qsy1 .. qsy4 - Yes - qsy1 to qsy4, cf. [PAC], p. 614
Section [SCALING_COEFFICIENTS]
This section specifies the MF 2002 scaling coefficients:
lfz0 .. lmy - No 1 lfz0 to lmy, cf. [PAC], p. 614
