mdlIObject AddAssemblyPlaceholder
Adds an assembly placeholder.
mdlIObject_handle AddAssemblyPlaceholder new_handle, varname, label, assembly_type, assembly_tag
MotionView Tcl Modify
This command adds an assembly placeholder using the ‘varname’, ‘label’, and ‘assembly_type’ arguments. As the name suggests, the AssemblyPlaceholder is just a place holder for an assembly. It can be understood as an assembly (void) where the data file and the definition file are not yet selected.
new_handle
The handle of the newly created assembly placeholder.
varname
The variable name of the assembly placeholder.
label
The label for the assembly placeholder.
assembly_type
The definition type that should be selected to create the assembly. The data file should have the same ‘assembly_type’ so that it can be selected to assembly placeholder.
assembly_tag
The tag for the assembly placeholder.
To add an assembly placeholder:
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetObjectHandle obj_handle
obj_handle AddAssemblyPlaceholder assem_handle assem_0 "\"Assembly Placeholder 0\"" Front_Half  Front_Half;
assem_handle ReleaseHandle;
obj_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
Returns the handle of the newly created assembly if successful. If there is an error, an error code will be returned.
