mdlIObject GetSourceFile
Obtains information about the source file for the assembly created in the model.
mdlIObject_Handle GetSourceFile type
MotionView Tcl Query
This command obtains information about the source file for the assembly created in the model.
type
The type of source file requested. Valid arguments are: DATA and DEFINITION.
You need to load an assembly prior to running this example.
To get the source file of a given assembly:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle myAssembly assem_0
set temp [myAssembly GetSourceFile DATA];
tk_messageBox -message "The Source of the Assembly is: $temp";
myAssembly ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns the file name including the path and Library name.
