mdlIObject IsEqual
Determines if two handles point to the same object.
mdlIObject_handle IsEqual other_handle
MotionView Tcl Query
This command determines if two handles point to the same object. This command can be used in case a single object has been obtained by two different handles. This command is useful when you want to remove the extra handles that are holding the same object.
- other_handle
- The name of the handle which is to be checked against the present handle of the object.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle hand1 p_cp
myModelName GetChildHandle hand2 p_cp
myModelName GetChildHandle hand3 p_sp
tk_messageBox -message "object1 equals object2 - [hand1 IsEqual hand2]";
tk_messageBox -message "object1 equals object3 - [hand1 IsEqual hand3]";
tk_messageBox -message "object2 equals object3 - [hand2 IsEqual hand3]";
hand1 ReleaseHandle
hand2 ReleaseHandle
hand3 ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns true if the two handles are equal (meaning they both are pointing to same object), or false if the two handles are not equal.
