poISection GetOrientationMethod
Gets the section display mode, used to control polygon visibility for a Planar section type.
poISection_handle GetOrientationMethod
HyperView Tcl Query
This command retrieves the section display mode, used to control polygon visibility for a Planar section type. Options include: n1n2n3base, xaxis, yaxis, zaxis, normaltoscreen, or user.
None.
