poISection SetBaseTime
Sets the base time for a section cut.
poISection_handle SetBaseTime time
HyperView Tcl Modify
This command sets the section as deformable, and also sets the time in seconds. The base time for the deformable section will go to the closest frame in the current animator for the page.
- time
- The time value in seconds.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set sid [client_handle AddSection]
client_handle GetSectionHandle sect_handle $sid
sect_handle SetBaseTime 0.1
client_handle Draw
hwi CloseStack
Returns a non-zero value if an error occurs.
