poISection SetGridSpacingX
Sets the distance between each grid line on the local X axis for a Planar section type.
poISection_handle SetGridSpacingX distance
HyperView Tcl Modify
This command sets the distance on the local X axis in generic model units for a Planar section type.
distance
The distance between two grid lines.
To set the distance on the local X axis to 1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetSectionHandle section_handle 1
section_handle SetGridSpacingX 1.0
hwi CloseStack
None.
